Zum Hauptinhalt wechseln
Caterpillar B15 SIM Card Replacement
Was du brauchst
  1. Caterpillar B15 SIM Card Replacement, SIM Card: Schritt 1, Bild 1 von 1
    • Place the phone screen-side down and place thumb on the yellow and black switch. Slide the switch to the right to unlock the back covering for removal.
  2. Caterpillar B15 SIM Card Replacement: Schritt 2, Bild 1 von 2 Caterpillar B15 SIM Card Replacement: Schritt 2, Bild 2 von 2
    • Remove the back covering by gently lifting upwards from the bottom of the back covering. The back will snap off and the battery is exposed.
  3. Caterpillar B15 SIM Card Replacement: Schritt 3, Bild 1 von 2 Caterpillar B15 SIM Card Replacement: Schritt 3, Bild 2 von 2
    • Place index finger at the top edge of the battery and gently lift upwards. The battery will slide cleanly out of the phone. The SIM card slot lies under the battery.
  4. Caterpillar B15 SIM Card Replacement: Schritt 4, Bild 1 von 1
    • The old SIM card is removed and replaced with the new one. The phone can be reassembled by following these steps in reverse order.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Geoffrey Mosdell
1.119 Reputation
5 Anleitungen geschrieben
USF Tampa, Team 4-7, Brown Fall 2014 Mitglied von USF Tampa, Team 4-7, Brown Fall 2014
USFT-BROWN-F14S4G7
4 Mitglieder
10 Anleitungen geschrieben
Ein Kommentar
Mi celular dice SIM no detectada que puedo hacer
Jerson Vargas - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 30
Insgesamt: 15,318
