Einleitung
Having problems with the ceiling dome light not turning on? This guide will help you fix the ceiling dome light, if the wiring is wrong.
Was du brauchst
Unscrew the screws halfway.
Twist the base of the light fixture to take it off.
Remove the black wire first, since it is the power. Then the white and copper wire.
Once you have twisted the base of the light fixture, the base will come down.
Twist each wire from the base of the light fixture to the wire in the ceiling.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
