Zum Hauptinhalt wechseln
Ceiling Fan Light Fixture Replacement
Was du brauchst
  1. Ceiling Fan Light  Fixture Replacement, Light Fixture: Schritt 1, Bild 1 von 3 Ceiling Fan Light  Fixture Replacement, Light Fixture: Schritt 1, Bild 2 von 3 Ceiling Fan Light  Fixture Replacement, Light Fixture: Schritt 1, Bild 3 von 3
    • Working with electrical wires could lead to electrocution.
    • Find your circuit breaker panel and turn off the breaker that corresponds to your ceiling lights.
    • Do this by pushing it to the right.
    • Also flip your light switch to off.
  2. Ceiling Fan Light  Fixture Replacement: Schritt 2, Bild 1 von 2 Ceiling Fan Light  Fixture Replacement: Schritt 2, Bild 2 von 2
    • Remove the two 1.4 mm Phillips head screws that hold the fixture to the fan itself.
    • Once loose, pull down to expose the two connecting wires.
  3. Ceiling Fan Light  Fixture Replacement: Schritt 3, Bild 1 von 3 Ceiling Fan Light  Fixture Replacement: Schritt 3, Bild 2 von 3 Ceiling Fan Light  Fixture Replacement: Schritt 3, Bild 3 von 3
    • Disconnect these wires by twisting the caps in a counter-clockwise direction.
    • You only need to disconnect the wires coming from the lighting fixture.
    • Once both caps are removed, simply pull the wires apart to remove the fixture.
  4. Ceiling Fan Light  Fixture Replacement: Schritt 4, Bild 1 von 2 Ceiling Fan Light  Fixture Replacement: Schritt 4, Bild 2 von 2
    • Loosen the nut holding the ceiling fan piece to the lighting fixture.
    • This step may require a crescent wrench if finger force is not enough.
  5. Ceiling Fan Light  Fixture Replacement: Schritt 5, Bild 1 von 1
    • Pull upwards to remove the fan piece that holds the light fixture.
    • Your model may require you to twist this piece in a counter-clockwise motion to remove.
  6. Ceiling Fan Light  Fixture Replacement: Schritt 6, Bild 1 von 1
    • Switch out the old fixture with your new fixture by doing the last two steps in reverse order.
  7. Ceiling Fan Light  Fixture Replacement: Schritt 7, Bild 1 von 2 Ceiling Fan Light  Fixture Replacement: Schritt 7, Bild 2 von 2
    • To connect your new fixture, locate the black wire from your light and the colored wire from the fan.
    • Be sure to attached the colored wires to each other, and white wires to each other. (Positive-Positive, Negative-Negative)
    • Twist these together. Do the same with the two white wires.
  8. Ceiling Fan Light  Fixture Replacement: Schritt 8, Bild 1 von 2 Ceiling Fan Light  Fixture Replacement: Schritt 8, Bild 2 von 2
    • Your new light fixture should come with replacement caps. Twist these in a clockwise motion over your wire ends to ensure connection.
    • The old caps work just as well for this if you were not given new ones.
  9. Ceiling Fan Light  Fixture Replacement: Schritt 9, Bild 1 von 1
    • Be sure to neatly tuck in all wires when re-attaching the fixture.
    • Failure to do this will result in not being able to correctly close the gap and put in the screws.
  10. Ceiling Fan Light  Fixture Replacement: Schritt 10, Bild 1 von 1
    • Flip your breaker back on, turn on your light switch, and enjoy your new lights!
Abschluss
12 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team 14-1, Green Fall 2015 Mitglied von Cal Poly, Team 14-1, Green Fall 2015
CPSU-GREEN-F15S14G1
4 Mitglieder
4 Anleitungen geschrieben
11 Kommentare
Amazingly instructive, informative and concise. Brilliant.
Jeanie Bolin-Moore - Antwort
Just what I needed. Thanks.
bob.mohler - Antwort
Could someone provide the name of the light fixture used in the demonstration?
THOMAS DUFF - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 23
Letzte 30 Tage: 119
Insgesamt: 34,537
