Zum Hauptinhalt wechseln
Ceiling Fan Pull Chain Switch Replacement
Was du brauchst
  1. Ceiling Fan Pull Chain Switch Replacement, Pull Chain Switch: Schritt 1, Bild 1 von 2 Ceiling Fan Pull Chain Switch Replacement, Pull Chain Switch: Schritt 1, Bild 2 von 2
    • Caution: Turn off the power from the circuit breaker and turn off any light switches that provide power to the ceiling fan.
    • Remove the white cover by unscrewing the nut on the bottom from where the chain is hanging.
  2. Ceiling Fan Pull Chain Switch Replacement: Schritt 2, Bild 1 von 3 Ceiling Fan Pull Chain Switch Replacement: Schritt 2, Bild 2 von 3 Ceiling Fan Pull Chain Switch Replacement: Schritt 2, Bild 3 von 3
    • Caution: Let the bulbs cool off before you remove them.
    • Remove the bulbs from their sockets.
  3. Ceiling Fan Pull Chain Switch Replacement: Schritt 3, Bild 1 von 2 Ceiling Fan Pull Chain Switch Replacement: Schritt 3, Bild 2 von 2
    • Remove the screws around the base.
    • Remove the fan housing.
  4. Ceiling Fan Pull Chain Switch Replacement: Schritt 4, Bild 1 von 1
    • Pull the switch out of the fan housing, leaving the wires attached.
  5. Ceiling Fan Pull Chain Switch Replacement: Schritt 5, Bild 1 von 3 Ceiling Fan Pull Chain Switch Replacement: Schritt 5, Bild 2 von 3 Ceiling Fan Pull Chain Switch Replacement: Schritt 5, Bild 3 von 3
    • Cut the colored wires from the switch using a pair of wire cutters.
    • On some switch models, the wires can be detached by pulling.
  6. Ceiling Fan Pull Chain Switch Replacement: Schritt 6, Bild 1 von 3 Ceiling Fan Pull Chain Switch Replacement: Schritt 6, Bild 2 von 3 Ceiling Fan Pull Chain Switch Replacement: Schritt 6, Bild 3 von 3
    • Note the wire colors and the terminal they attach to on the old switch.
    • 1 - Red
    • 2 - Purple
    • 3 - Yellow
    • L - Black
  7. Ceiling Fan Pull Chain Switch Replacement: Schritt 7, Bild 1 von 1
    • Attach the colored wires to the new switch's respective terminals.
  8. Ceiling Fan Pull Chain Switch Replacement: Schritt 8, Bild 1 von 2 Ceiling Fan Pull Chain Switch Replacement: Schritt 8, Bild 2 von 2
    • Put back the switch in the hole in the fan housing from the inside.
    • Tighten up the screws on the outside.
  9. Ceiling Fan Pull Chain Switch Replacement: Schritt 9, Bild 1 von 3 Ceiling Fan Pull Chain Switch Replacement: Schritt 9, Bild 2 von 3 Ceiling Fan Pull Chain Switch Replacement: Schritt 9, Bild 3 von 3
    • Put back the white cover and then tighten up the nut at the bottom of the cover from where the chain is hanging.
  10. Ceiling Fan Pull Chain Switch Replacement: Schritt 10, Bild 1 von 2 Ceiling Fan Pull Chain Switch Replacement: Schritt 10, Bild 2 von 2
    • Turn the power back on and test the switch to find if it is working or not.
Ziellinie
3 weitere Personen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 12
Letzte 7 Tage: 56
Letzte 30 Tage: 185
Insgesamt: 13,701
