Einleitung
Replacing the display on this device is not very difficult. A couple sets of screws and wires are all that need removing, but don't rush or you might rip a cable.
Was du brauchst
Lay the device on its back, and rotate so the base is facing away from you.
Grip the frame with your fingers under the edge of the frame, and thumbs pushing down on the front of the device.
Lift up the frame with your fingers and push down the rest of the device with your thumbs.
Using the plastic opening tool or your fingers, lift up the frame from any edge.
Remove the frame from the device.
Unplug the cable connecting the display to the power supply using the flat end of the spudger to pry the connector away from the circuit board.
Use the spudger to disconnect the ribbon cable from the display by the black pins away from the connector. There is a pin on either side of the connector.
Once both pins are released, the ribbon cable should slide easily out.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
