Zum Hauptinhalt wechseln
Ceiva LF2003 Exterior Frame and Matting Replacement
  1. Ceiva LF2003 Exterior Frame and Matting Replacement, Exterior Frame and Matting: Schritt 1, Bild 1 von 1
    • Lay the device on its back, and rotate so the base is facing away from you.
  2. Ceiva LF2003 Exterior Frame and Matting Replacement: Schritt 2, Bild 1 von 1
    • Grip the frame with your fingers under the edge of the frame, and thumbs pushing down on the front of the device.
  3. Ceiva LF2003 Exterior Frame and Matting Replacement: Schritt 3, Bild 1 von 1
    • Lift up the frame with your fingers and push down the rest of the device with your thumbs.
  4. Ceiva LF2003 Exterior Frame and Matting Replacement: Schritt 4, Bild 1 von 1
    • Remove the frame and matte from the device.
Abschluss
Casey Glasgow
510 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 9-25, Maness Winter 2014 Mitglied von Cal Poly, Team 9-25, Maness Winter 2014
CPSU-MANESS-W14S9G25
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 102
