Einleitung
If the 'on'/'off' switch of the device is stuck in the 'off' position, the device will not turn on. This guide will show how to access and replace the switch from within.
Was du brauchst
Place the meter face down, and the back panel and screws can be seen.
Unscrew the two 9mm screws on the back panel using a #0 Phillips screwdriver.
Remove the back panel of the device by lifting upward.
Remove the battery from the meter before continuing.
Remove the four 7mm Phillips screws holding the circuit board in place.
The 'on'/'off' switch is located directly beneath the dial.
Gently remove switch from device by lifting upward.
Either clean or replace switch.
4 weitere Personen haben diese Anleitung absolviert.
Ein Kommentar
Hi Great site love it, Where can you purchase the copper contacts and is there a technical name for them didn’t know that I could have repaired much craftsman 82040 meter by piecing out the harbor freight free meterand using the contacts which were worn out and non repairable and started to hand make them and then ran across this site. Thanks for the tutorial and being part of the solution as i am an automotive parts rebuilder keeping land fills few of good core since 1988.
