Zum Hauptinhalt wechseln
Cen-Tech Seven Function Digital Multimeter Screen Replacement
Was du brauchst
  1. Cen-Tech Seven Function Digital Multimeter Screen Replacement, Position Device: Schritt 1, Bild 1 von 1
    • Place the meter face down, and the back panel and screws can be seen.
  2. Cen-Tech Seven Function Digital Multimeter Screen Replacement, Remove Back Panel Screws: Schritt 2, Bild 1 von 2 Cen-Tech Seven Function Digital Multimeter Screen Replacement, Remove Back Panel Screws: Schritt 2, Bild 2 von 2
    • Unscrew the two 9mm screws on the back panel using a #0 Phillips screwdriver.
  3. Cen-Tech Seven Function Digital Multimeter Screen Replacement, Remove Back Panel: Schritt 3, Bild 1 von 1
    • Remove the back panel of the device by lifting upward.
    • Remove the battery from the meter before continuing.
  4. Cen-Tech Seven Function Digital Multimeter Screen Replacement, Unscrew Motherboard: Schritt 4, Bild 1 von 2 Cen-Tech Seven Function Digital Multimeter Screen Replacement, Unscrew Motherboard: Schritt 4, Bild 2 von 2
    • Remove the four 7mm Phillips screws holding the circuit board in place.
  5. Cen-Tech Seven Function Digital Multimeter Screen Replacement, Remove Motherboard: Schritt 5, Bild 1 von 1
    • Gently lift the circuit board away from the device casing.
    • Remove the battery after removing the back cover to reduce the chances of short-circuiting the circuit board.
  6. Cen-Tech Seven Function Digital Multimeter Screen Replacement, Locate Screen: Schritt 6, Bild 1 von 1
    • The screen is located at the top of the device.
  7. Cen-Tech Seven Function Digital Multimeter Screen Replacement, Remove Screen: Schritt 7, Bild 1 von 1
    • Carefully remove screen from device by lifting upward.
Abschluss
Anna Kihm
956 Reputation
5 Anleitungen geschrieben
Clemson, Team 2-4, Benson Fall 2014 Mitglied von Clemson, Team 2-4, Benson Fall 2014
CLEM-BENSON-F14S2G4
4 Mitglieder
6 Anleitungen geschrieben
1 Kommentar zur Anleitung
my multimeter display is broken, where can i buy a new one?
allwynrajkumar - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 18
Insgesamt: 2,819
