Zum Hauptinhalt wechseln
Chamberlain Garage Door Sensor Replacement
Was du brauchst
  1. Chamberlain Garage Door Sensor Replacement, Sensor: Schritt 1, Bild 1 von 1
    • Use a step ladder to reach and unplug the garage door opener power cord.
    Frag FixBot
    Kommentar hinzufügen
  2. Chamberlain Garage Door Sensor Replacement: Schritt 2, Bild 1 von 1
    • Remove the wingnut from the safety sensor bracket.
    • Turn counter-clockwise until the wingnut is completely removed.
    Frag FixBot
  3. Chamberlain Garage Door Sensor Replacement: Schritt 3, Bild 1 von 2 Chamberlain Garage Door Sensor Replacement: Schritt 3, Bild 2 von 2
    • Pull the sensor from the bracket.
    • Be careful not to lose the screw that attaches the sensor to the bracket.
    Frag FixBot
  4. Chamberlain Garage Door Sensor Replacement: Schritt 4, Bild 1 von 1
    • Use the wire stripper or pliers to cut the wires for the sensor about an inch from the safety sensor.
    • This step removes the old sensor.
    Frag FixBot
  5. Chamberlain Garage Door Sensor Replacement: Schritt 5, Bild 1 von 3 Chamberlain Garage Door Sensor Replacement: Schritt 5, Bild 2 von 3 Chamberlain Garage Door Sensor Replacement: Schritt 5, Bild 3 von 3
    • Separate the ends of the wires
    • Use the wire stripper to strip the ends of the wires for the new sensor.
    • This step prepares the new sensor to be connected to the wiring for the garage door opener.
    Frag FixBot
  6. Chamberlain Garage Door Sensor Replacement: Schritt 6, Bild 1 von 3 Chamberlain Garage Door Sensor Replacement: Schritt 6, Bild 2 von 3 Chamberlain Garage Door Sensor Replacement: Schritt 6, Bild 3 von 3
    • Separate the ends of the wires and use the wire stripper to strip the ends of the wires going into the wall.
    • This step prepares the garage door opener wiring to be connected to the new sensor.
    Frag FixBot
  7. Chamberlain Garage Door Sensor Replacement: Schritt 7, Bild 1 von 3 Chamberlain Garage Door Sensor Replacement: Schritt 7, Bild 2 von 3 Chamberlain Garage Door Sensor Replacement: Schritt 7, Bild 3 von 3
    • Match the wires from the wall and from the new sensor and connect them with the crimp by inserting two like-kind wires in one crimp with one wire going into each side.
    • The black striped goes with the black striped wire.
    Frag FixBot
  8. Chamberlain Garage Door Sensor Replacement: Schritt 8, Bild 1 von 3 Chamberlain Garage Door Sensor Replacement: Schritt 8, Bild 2 von 3 Chamberlain Garage Door Sensor Replacement: Schritt 8, Bild 3 von 3
    • Use the pair of pliers to press down on the round section of the crimp to seal the connection.
    • Repeat for the other wire.
    Frag FixBot
  9. Chamberlain Garage Door Sensor Replacement: Schritt 9, Bild 1 von 1
    • With the wiring connected, slide the new sensor into the bracket.
    Frag FixBot
  10. Chamberlain Garage Door Sensor Replacement: Schritt 10, Bild 1 von 1
    • Attach the wingnut and tighten the new sensor to the bracket.
    Frag FixBot
  11. Chamberlain Garage Door Sensor Replacement: Schritt 11, Bild 1 von 1
    • Repeat the process for the other sensor on the other side of the garage door.
    Frag FixBot
  12. Chamberlain Garage Door Sensor Replacement: Schritt 12, Bild 1 von 1
    • Use a step ladder to reach and plug in the power cord for the garage door sensor.
    Frag FixBot
  13. Chamberlain Garage Door Sensor Replacement: Schritt 13, Bild 1 von 2 Chamberlain Garage Door Sensor Replacement: Schritt 13, Bild 2 von 2
    • Gently wiggle the sensors to align them.
    • When the sensors are aligned, the sensor with the green safety light glows steadily.
    Frag FixBot
  14. Chamberlain Garage Door Sensor Replacement: Schritt 14, Bild 1 von 3 Chamberlain Garage Door Sensor Replacement: Schritt 14, Bild 2 von 3 Chamberlain Garage Door Sensor Replacement: Schritt 14, Bild 3 von 3
    • Place a box between the sensors and press the garage door button to close the garage door. The garage door should return to its starting point and the garage door light flash. This result means that the new sensors are working properly.
    Frag FixBot
Ziellinie
Orrett Bailey
229 Reputation
1 Anleitung geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 8
Letzte 7 Tage: 49
Letzte 30 Tage: 243
Insgesamt: 2,512
