Zum Hauptinhalt wechseln
Changing the thermostatic cartridge - Thermostatic Bath NF SIRYO CHROME
  1. Changing the thermostatic cartridge - Thermostatic Bath NF SIRYO CHROME, Required tools: Schritt 1, Bild 1 von 1
    • 24mm wrench
    • 21mm wrench
    • Flathead screwdriver
    • Phillips screwdriver
  2. Changing the thermostatic cartridge - Thermostatic Bath NF SIRYO CHROME, Access to the inverter: Schritt 2, Bild 1 von 3 Changing the thermostatic cartridge - Thermostatic Bath NF SIRYO CHROME, Access to the inverter: Schritt 2, Bild 2 von 3 Changing the thermostatic cartridge - Thermostatic Bath NF SIRYO CHROME, Access to the inverter: Schritt 2, Bild 3 von 3
    • ATTENTION: Before any disassembly of the inverter, remember to close the water supply from the meter.
    • Check that the position of the reverse handle is on 'OFF'
    • Using a small flat screwdriver, unclip the access cover to the screw that holds it in place.
    • Using a Phillips screwdriver, unscrew the fixing screw of the handle.
  3. Changing the thermostatic cartridge - Thermostatic Bath NF SIRYO CHROME, Removal of the handle of the inverter: Schritt 3, Bild 1 von 2 Changing the thermostatic cartridge - Thermostatic Bath NF SIRYO CHROME, Removal of the handle of the inverter: Schritt 3, Bild 2 von 2
    • Unscrew the handle.
  4. Changing the thermostatic cartridge - Thermostatic Bath NF SIRYO CHROME, Disassembly of the inverter: Schritt 4, Bild 1 von 2 Changing the thermostatic cartridge - Thermostatic Bath NF SIRYO CHROME, Disassembly of the inverter: Schritt 4, Bild 2 von 2
    • Using a 24 flat wrench, unscrew the nut counterclockwise.
    • Remove the inverter.
  5. Changing the thermostatic cartridge - Thermostatic Bath NF SIRYO CHROME, Replacement of the inverter: Schritt 5, Bild 1 von 3 Changing the thermostatic cartridge - Thermostatic Bath NF SIRYO CHROME, Replacement of the inverter: Schritt 5, Bild 2 von 3 Changing the thermostatic cartridge - Thermostatic Bath NF SIRYO CHROME, Replacement of the inverter: Schritt 5, Bild 3 von 3
    • Replacing the inverter
    • Please make sure to properly align the pin of the diverter with the notch indicated by the arrow in the body of the faucet.
  6. Changing the thermostatic cartridge - Thermostatic Bath NF SIRYO CHROME, Reassembly: Schritt 6, Bild 1 von 3 Changing the thermostatic cartridge - Thermostatic Bath NF SIRYO CHROME, Reassembly: Schritt 6, Bild 2 von 3 Changing the thermostatic cartridge - Thermostatic Bath NF SIRYO CHROME, Reassembly: Schritt 6, Bild 3 von 3
    • Insert the diverter into the body of the faucet.
    • Hand-tighten the inverter mounting nut clockwise.
    • Finish tightening using the 24mm wrench.
  7. Changing the thermostatic cartridge - Thermostatic Bath NF SIRYO CHROME, Putting the handle back in place: Schritt 7, Bild 1 von 3 Changing the thermostatic cartridge - Thermostatic Bath NF SIRYO CHROME, Putting the handle back in place: Schritt 7, Bild 2 von 3 Changing the thermostatic cartridge - Thermostatic Bath NF SIRYO CHROME, Putting the handle back in place: Schritt 7, Bild 3 von 3
    • Align the reference point of the faucet body with the "OFF" marking on the handle.
    • Tighten the fixing screw of the handle using a Phillips screwdriver in a clockwise direction.
    • Put the cover back in place.
Ziellinie
3 weitere Personen haben diese Anleitung absolviert.
fr en
100%
Hier starten ›
iRobot
1 Reputation
636 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 10
Letzte 30 Tage: 38
Insgesamt: 1,114
