Einleitung
The purpose of this guide is to help grill owners patch rusty and corroded drip pans on Charbroil grills with permanently riveted drip pans. Rather than discarding the grill and spending hundreds of dollars for a new one, this procedure will allow the grill owner to extend the usable life of his or her grill.
Was du brauchst
Make an initial assessment of the extent of the corrosion to the drip pan.
Use a wire brush to remove the most corroded metal.
Use the tin snips to remove the least corroded metal.
Remove the large chunks of rusty metal by hand.
Use a dustpan and a hand broom to sweep up the smaller bits of rust.
Remove any remaining dust or debris with a small shop vacuum.
Measure and record the width of the drip pan opening.
Measure and record the height of the drip pan opening.
Measure and cut a piece of low gauge sheet metal to cover the dimensions of the drip pan opening.
Position the cut sheet metal over the drip pan opening.
Use the duct tape to secure the metal in place for attachment with the self-drilling sheet metal screws.
Use a power drill and the #10 x 1/2 self-drilling sheet metal screws to secure each corner of the replacement sheet metal.
Remove the duct tape when the sheet metal is secure.
Secure the remaining edges of the sheet metal with additional screws as needed to ensure a tight fit.
Ensure that the sheet metal screws have secured the replacement sheet metal patch.
Cut the 3M High Temperature Flue tape to the proper length (this will depend upon the size of the patch).
Place the tape over the sheet metal screws and cover the edges to seal the edges of the patch.
Drill four pilot holes through the grease outlet from the top side of the grill using either a cordless or power drill. These holes will be used later to provide space to use the tin snips.
Cut the remaining metal between the pilot holes with the tin snips to form a single grease outlet.
Use a metal file to file away the rough edges of the newly created grease outlet.
Cut the 3M high-temperature flue tape to cover the remaining edges of the sheet metal.
Tape the flue tape over the metal edges of the grease outlet for safety.
Upon completion, this repair will extend the usable life of your grill and reduce waste deposited into landfills.
3 weitere Personen haben diese Anleitung absolviert.
2 Kommentare
Thank you so much for posting this. Question: what type of sheet metal? Aluminum or Steel?
What kind of material? Aluminum?
