Einleitung
This repair helps fix bad battery life which could cause the device to reboot at random
Was du brauchst
Remove both T2 screws
Slide off the plastic piece by lifting out and then up
Slide plastic and spring assembly off the rail
Heat the glass screen with a blowdryer to soften the adhesives
Insert a razor blade between the glass and the body
Keep going around the rim of the display until loose
Connect new battery connector
Peel the plastic layer off the adhesive backing
Put the battery back in place
Flip down the screen and remove any extra glue that squeezes out
Take a rubber band and wrap it around the device, this will ensure the display stays in place until the glue cures
With the rubber bands on go to step 1 and reverse the steps to reinstall the band release
When the glue is fully cured remove the rubber bands
And walla you now have a repaired Fitbit Charge 3
Thanks to ShellingRook27's Original Dissasembly I Was Able to Make this Guide And Bring a new life to my old device.
2 Kommentare
No problem anything to make the world a more fixable place
