Zum Hauptinhalt wechseln
Einleitung
This is a basic guide on how to check your audio/video cables and to make sure that they are all plugged in correctly.
  1. Make sure that colors match between back of device and cables
    • Make sure that colors match between back of device and cables
    • Make sure cables are pressed firmly into both devices at each end of the cable
  2. MacBook Akku Fix Kits
    Ab $69.99
    Buy Now
    Ab $69.99
    Buy Now
  3. Make sure that cables going to the television are not connected to the outputs circled in red.
    • Make sure that cables going to the television are not connected to the outputs circled in red.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Nathan Cheadle
137 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 16-5, Maness Spring 2010 Mitglied von Cal Poly, Team 16-5, Maness Spring 2010
CPSU-MANESS-S10S16G5
4 Mitglieder
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 671
