Einleitung
Sharpening is essentially what the chef's choice is about. This is achieved by the sharpening stones and will frequently need to be replaced. Extra caution to be taken on the removal of the c-clips as they can easily spring out and get lost.
Was du brauchst
Remove the two rubber feet on the motor side of the device.
Remove the five Phillips screws from the bottom of the case.
Carefully flip the device right-side-up while grasping the top and bottom pieces.
With the outer case removed, firmly grasp the motor-axle attachment and remove it from the base. It should come right off of the assembly.
Use a screwdriver to push the linkage pins out of the rod.
Use pliers to pull the pins the rest of the way out.
Remove the C-clamps by applying pressure to both sides of the "C" and pushing the clamp over and off of the axle.
Pull the bearing off the shaft. It is in between the two C-clamps.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
4 Kommentare
where does one get the replacement stones. im not seeing they in my amazon/google searches. also cant seem to see them on manufacturers website section for parts.
I have the same question.
same question, where do I order replacement stones ?? I have the chef’s choice Sportsman from cabelas, thanks in advance .. you can send any info to my e-mail thebobster@ns.sympatico.ca any info wiuld be greatly appreciated..
