Zum Hauptinhalt wechseln
Chefman RJ-38-V2-35 Fryer Basket Replacement
Was du brauchst
  1. Chefman RJ-38-V2-35 Fryer Basket Replacement, Fryer Basket: Schritt 1, Bild 1 von 1
    • Make sure the air fryer is unplugged and the basket is cool enough to handle.
    • Remove the basket from the air fryer.
  2. Chefman RJ-38-V2-35 Fryer Basket Replacement: Schritt 2, Bild 1 von 1
    • Place the fryer basket on a flat surface.
    • Using the Phillips #1 screwdriver, remove four 5mm screws on the inside of the fryer basket (left two screws shown).
  3. Chefman RJ-38-V2-35 Fryer Basket Replacement: Schritt 3, Bild 1 von 1
    • Separate the handle from the basket.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
UW Tacoma, Team S1-G4, Rose Fall 2018 Mitglied von UW Tacoma, Team S1-G4, Rose Fall 2018
UWT-ROSE-F18S1G4
4 Mitglieder
3 Anleitungen geschrieben
4 Kommentare
I need the plate inside the basket. The coating is coming off, Is it safe to use?
Eileen Morrison - Antwort
Where can I buy only the basket or just the plate? I need replacement but don’t seem to find the parts…
Eszter Stranszky - Antwort
I need the plate inside the basket. Coating is coming off.
Sandy Mentzer - Antwort
Where can I buy replacement rubber feet for the fryer basket plate? Mine came off and went down the disposal!! Are they required for proper heating and frying??
Betty Johnson - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 7
Letzte 30 Tage: 53
Insgesamt: 3,547
