Zum Hauptinhalt wechseln
Chefman RJ38-V2-35 Repair Temperature Knob Replacement
Was du brauchst
  1. Chefman RJ38-V2-35 Repair Temperature Knob  Replacement, Temperature Knob: Schritt 1, Bild 1 von 1
    • Please be sure that the device is unplugged and remove the frying basket from the device.
    • Orient your device where the both the timer knob and temperature knob are facing you.
    • Slide the plastic opening tool under the temperature knob to lift it up.
    • You can slide your fingers in between the gap and take the temperature knob off.
  2. Chefman RJ38-V2-35 Repair Temperature Knob  Replacement: Schritt 2, Bild 1 von 1
    • Using the Phillips #1 screwdriver, remove the two 4mm screws found under the temperature knob.
    • Place you fingers under the silver top and firmly lift it up.
  3. Chefman RJ38-V2-35 Repair Temperature Knob  Replacement: Schritt 3, Bild 1 von 3 Chefman RJ38-V2-35 Repair Temperature Knob  Replacement: Schritt 3, Bild 2 von 3 Chefman RJ38-V2-35 Repair Temperature Knob  Replacement: Schritt 3, Bild 3 von 3
    • Using the Phillips #1 screwdriver, remove the two 3 mm screws found at the top of the black panel.
    • Pop off the top panel of the device with your fingers.
  4. Chefman RJ38-V2-35 Repair Temperature Knob  Replacement: Schritt 4, Bild 1 von 1
    • Using a pair of scissors, cut off the cable cord that is securing the wire cords.
  5. Chefman RJ38-V2-35 Repair Temperature Knob  Replacement: Schritt 5, Bild 1 von 3 Chefman RJ38-V2-35 Repair Temperature Knob  Replacement: Schritt 5, Bild 2 von 3 Chefman RJ38-V2-35 Repair Temperature Knob  Replacement: Schritt 5, Bild 3 von 3
    • Detach the device’s wires from the potentiometer.
  6. Chefman RJ38-V2-35 Repair Temperature Knob  Replacement: Schritt 6, Bild 1 von 1
    • Replace a new potentiometer to the device.
    • Attach the wires back to the new potentiometer.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Lucas Yi
156 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 30
Insgesamt: 2,313
