Zum Hauptinhalt wechseln
Chevy 305 Engine Connecting Rod Bearing Replacement
Was du brauchst
  1. Chevy 305 Engine Connecting Rod Bearing Replacement, Connecting Rod Bearing: Schritt 1, Bild 1 von 2 Chevy 305 Engine Connecting Rod Bearing Replacement, Connecting Rod Bearing: Schritt 1, Bild 2 von 2
    • Remove the 18 bolts holding the oil pan in place using the 3⁄8 and 1⁄2 sockets, 6 inch extension and 3⁄8 ratchet.
    • Fourteen 3/8 bolts around the perimeter and four 1/2 bolts on each corner
    • Lift the oil pan up and forward so the oil pump pick up will clear the baffle.
    • Do not remove the oil pan gasket yet.
  2. Chevy 305 Engine Connecting Rod Bearing Replacement: Schritt 2, Bild 1 von 1
    • Remove the two 5/8 nuts on the connecting rod end cap using the 5/8 socket
    • Gently tap the side of the cap with a rubber mallet if needed to break free.
  3. Chevy 305 Engine Connecting Rod Bearing Replacement: Schritt 3, Bild 1 von 1
    • Remove and replace connecting rod bearing
    • Gently tap the end cap against the engine block or use a thin flathead screwdriver to remove it from the end cap.
    • Gently move the piston and rod down into the cylinder to replace the rod end bearing.
    • DO NOT PUSH THE PISTON OUT OF THE CYLINDER.
  4. Chevy 305 Engine Connecting Rod Bearing Replacement: Schritt 4, Bild 1 von 1
    • Liberally apply assembly lubricant/oil to the new bearing surfaces and crankshaft journal.
Abschluss
To reassemble your device, follow these instructions in reverse order. Torque the connecting rod cap nuts to 65ft.-lbs. Torque the oil pan bolts to 12ft.-lbs.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Joey Barton
364 Reputation
3 Anleitungen geschrieben
University of Memphis, Team S4-G3, Kim Fall 2019 Mitglied von University of Memphis, Team S4-G3, Kim Fall 2019
UM-KIM-F19S4G3
3 Mitglieder
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 58
Insgesamt: 2,223
