Zum Hauptinhalt wechseln
HP Chromebook 14-x015wm Battery Replacement
Was du brauchst
  1. HP Chromebook 14-x015wm Battery Replacement, Battery: Schritt 1, Bild 1 von 2 HP Chromebook 14-x015wm Battery Replacement, Battery: Schritt 1, Bild 2 von 2
    • Turn the Chromebook upside down so that the bottom is facing upwards.
    • Remove the small rubber circles from all four corners.
    • Remove the other three rubber pads from the bottom
    • Proceed to unscrew all the screws.
    • Keep the screws on a magnetic mat or in a secure location and keep track of which screws went where.
  2. HP Chromebook 14-x015wm Battery Replacement: Schritt 2, Bild 1 von 1
    • Flip the laptop back over and open it so that the keyboard is revealed to you.
    • Use a plastic opening tool to pry off the keyboard. It's slightly difficult to get off, but go evenly around all four sides until it pops out.
    • Be careful of the ribbons underneath that connect the keyboard to the internal components.
  3. HP Chromebook 14-x015wm Battery Replacement: Schritt 3, Bild 1 von 2 HP Chromebook 14-x015wm Battery Replacement: Schritt 3, Bild 2 von 2
    • The long, flat, black component that takes up the majority of the space is the battery.
    • All you are required to do is unscrew the screws attached to the battery and then gently remove the battery from the Chromebook.
    • Make sure to keep track of where the screws came from.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 25
Insgesamt: 1,359
