Zum Hauptinhalt wechseln
Chromebook 14-x015wm Key Replacement
Was du brauchst
  1. Chromebook 14-x015wm Key Replacement, Key: Schritt 1, Bild 1 von 1
    • Take a flathead screw driver and place it right under the key. Very gently pry it up. If it doesn't come off right away, try and loosen it by using the flathead on all four sides and wiggle it.
  2. Chromebook 14-x015wm Key Replacement: Schritt 2, Bild 1 von 1
    • Once the key is off, all you have to do to put a new key on is center it exactly how the original one was, and push down.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 208
