Einleitung
Sometimes keys get sticky and break and need to be replaced. Its really simple to do so!
Was du brauchst
Take a flathead screw driver and place it right under the key. Very gently pry it up. If it doesn't come off right away, try and loosen it by using the flathead on all four sides and wiggle it.
Once the key is off, all you have to do to put a new key on is center it exactly how the original one was, and push down.
Fast fertig!
Abschluss
