Zum Hauptinhalt wechseln
Chromebook 14-x015wm Keyboard Replacement
Was du brauchst
  1. Chromebook 14-x015wm Keyboard Replacement, Keyboard: Schritt 1, Bild 1 von 2 Chromebook 14-x015wm Keyboard Replacement, Keyboard: Schritt 1, Bild 2 von 2
    • Remove the small rubber circles over all four corners on the bottom of the chromebook.
    • Remove the three small additional rubber covers along edge of computer with hinge.
    • Unscrew all the screws on the bottom of the laptop using a Phillips #00 screwdriver.
    • Make sure to keep track of the screws for reassembly.
  2. Chromebook 14-x015wm Keyboard Replacement: Schritt 2, Bild 1 von 1
    • Flip the laptop back over to the front and open it so that the keyboard is visible.
    • Use the iFixit opening tool to pry off the keyboard by placing the tool in-between the keyboard and the case. Move the tool around all sides until the keyboard separates.
    • The keyboard will likely be difficult to remove.
    • Be careful to avoid pulling on the ribbons that connect the keyboard to the internal components in order to prevent damage.
  3. Chromebook 14-x015wm Keyboard Replacement: Schritt 3, Bild 1 von 1
    • Carefully unclip the ribbons under the keyboard to disconnect the keyboard.
    • Replace the keyboard and connect the ribbons to the new keyboard.
    • Press the computer case shut and replace the screws and rubber pads.
Ziellinie
2 weitere Nutzer:innen haben diese Anleitung absolviert.
UMass Dartmouth, Team S1-G2, Isaacson Fall 2017 Mitglied von UMass Dartmouth, Team S1-G2, Isaacson Fall 2017
UMASSD-ISAACSON-F17S1G2
2 Mitglieder
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 6
Insgesamt: 424
