Zum Hauptinhalt wechseln
Chromebook x360 14-da0011dx Fan Replacement
Was du brauchst
  1. Chromebook x360 14-da0011dx Fan Replacement, Lower Case: Schritt 1, Bild 1 von 1
    • Flip the device over with the hinge facing away from you.
    • On the back of the device, remove the two rubber strips on the top and the bottom of the device using a spudger.
  2. Chromebook x360 14-da0011dx Fan Replacement: Schritt 2, Bild 1 von 2 Chromebook x360 14-da0011dx Fan Replacement: Schritt 2, Bild 2 von 2
    • Remove the seven 8.0 mm screws located under the two rubber pads and the screws along the back of the device using a Phillips #1 screwdriver.
  3. Chromebook x360 14-da0011dx Fan Replacement: Schritt 3, Bild 1 von 3 Chromebook x360 14-da0011dx Fan Replacement: Schritt 3, Bild 2 von 3 Chromebook x360 14-da0011dx Fan Replacement: Schritt 3, Bild 3 von 3
    • Use a spudger to gently pry the edges of the back cover off the device. Slowly work all the way around the device until the panel comes loose.
  4. Chromebook x360 14-da0011dx Fan Replacement, Battery: Schritt 4, Bild 1 von 2 Chromebook x360 14-da0011dx Fan Replacement, Battery: Schritt 4, Bild 2 von 2
    • Remove the cable attached to the battery.
  5. Chromebook x360 14-da0011dx Fan Replacement: Schritt 5, Bild 1 von 2 Chromebook x360 14-da0011dx Fan Replacement: Schritt 5, Bild 2 von 2
    • Remove the five 3.0 mm screws holding the battery in place using the Phillips #1 screwdriver.
  6. Chromebook x360 14-da0011dx Fan Replacement: Schritt 6, Bild 1 von 1
    • Lift the battery out of the chassis.
  7. Chromebook x360 14-da0011dx Fan Replacement, Fan: Schritt 7, Bild 1 von 1
    • Remove the two 3.0 mm Phillips #1 screws holding the fan in place.
  8. Chromebook x360 14-da0011dx Fan Replacement: Schritt 8, Bild 1 von 2 Chromebook x360 14-da0011dx Fan Replacement: Schritt 8, Bild 2 von 2
    • Disconnect the fan cable from the motherboard.
    • Carefully remove the fan from the computer.
    • Be careful when removing the fan, as it sits under one of the CPU heat pipes and tucks under the ribbon cable that runs to the I/O board.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 16
Letzte 30 Tage: 28
Insgesamt: 164
