Einleitung
This guide offers instructions for replacing the motherboard on your Chromebook x360 14-da0011dx. Removal of the motherboard requires removing both the battery and cooling fan.
Note: When re-installing a new motherboard, the heat pipes and thermal paste may need to be installed on the new motherboard.
Was du brauchst
Flip the device over with the hinge facing away from you.
On the back of the device, remove the two rubber strips on the top and the bottom of the device using a spudger.
Remove the seven 8.0 mm screws located under the two rubber pads and the screws along the back of the device using a Phillips #1 screwdriver.
Use a spudger to gently pry the edges of the back cover off the device. Slowly work all the way around the device until the panel comes loose.
Remove the five 3.0 mm screws holding the battery in place using the Phillips #1 screwdriver.
Disconnect the fan cable from the motherboard.
Carefully remove the fan from the computer.
Lift the ZIF connector locking flaps, then remove the ribbon cables.
Disconnect the cables attached to the Wi-Fi card and motherboard along the top edge.
Gently lift the motherboard until it is loose.
Disconnect the ribbon cable attached to the underside of the motherboard.
Eine weitere Person hat diese Anleitung absolviert.
