Einleitung
This guide provides instructions for replacing the Wireless card in your Chromebook x360 14-da0011dx. If you're having problems with Wi-Fi connections, reseating or replacing the wireless card may be necessary.
Was du brauchst
Flip the device over with the hinge facing away from you.
On the back of the device, remove the two rubber strips on the top and the bottom of the device using a spudger.
Remove the seven 8.0 mm screws located under the two rubber pads and the screws along the back of the device using a Phillips #1 screwdriver.
Use a spudger to gently pry the edges of the back cover off the device. Slowly work all the way around the device until the panel comes loose.
Remove the plastic protector from the top of the wires plugged into the wireless card.
Remove the single 3 mm screw holding down the wireless card with the Phillips #1 screwdriver.
Disconnect the antenna cables leading into the wireless card.
Slide the wireless card out of its port and lift it out of the device.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
