Zum Hauptinhalt wechseln
Einleitung
Power buttons notoriously end up inside of devices if too much force is applied. This guide aims to replace the power button into it's desired location.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Place the Google Chromecast face down (with text not showing) on a flat surface.
    • Place the Google Chromecast face down (with text not showing) on a flat surface.
    • Insert a flat tool just above the micro-USB port to detach the top part of the case from the bottom.
  2. Continue prying the top of the case from the bottom toward the HDMI port until the top casing is completely removed.
    • Continue prying the top of the case from the bottom toward the HDMI port until the top casing is completely removed.
  3. Remove the circuit board, lifting from the HDMI port.
    • Remove the circuit board, lifting from the HDMI port.
    • The power button may become dislodged.
  4. Pry the plastic clamp from the heatsink.
    • Pry the plastic clamp from the heatsink.
    • Do not pry too hard to avoid breaking the clamp.
  5. Insert a plastic opening tool under the heatsink, and pry the heatsink up and out of the case. The adhesive's strength may vary, and force should be applied gently until it becomes dislodged to avoid breaking the device.
    • Insert a plastic opening tool under the heatsink, and pry the heatsink up and out of the case.
    • The adhesive's strength may vary, and force should be applied gently until it becomes dislodged to avoid breaking the device.
  6. Press the plastic button from the outside of the port, pushing it inward if it is stuck.
    • Press the plastic button from the outside of the port, pushing it inward if it is stuck.
Abschluss
Cameron Heiges
521 Reputation
3 Anleitungen geschrieben
IUPUI, Team S5-G6, Baechle Spring 2018 Mitglied von IUPUI, Team S5-G6, Baechle Spring 2018
IUPUI-BAECHLE-S18S5G6
3 Mitglieder
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 4
Letzten 7 Tage: 11
Letzten 30 Tage: 25
Insgesamt: 420
