Einleitung
Power buttons notoriously end up inside of devices if too much force is applied. This guide aims to replace the power button into it's desired location.
Was du brauchst
Place the Google Chromecast face down (with text not showing) on a flat surface.
Insert a flat tool just above the micro-USB port to detach the top part of the case from the bottom.
Continue prying the top of the case from the bottom toward the HDMI port until the top casing is completely removed.
Insert a plastic opening tool under the heatsink, and pry the heatsink up and out of the case.
Press the plastic button from the outside of the port, pushing it inward if it is stuck.
2 weitere Personen haben diese Anleitung absolviert.
