Zum Hauptinhalt wechseln
Chromo Inc. T2 Battery Replacement
Was du brauchst
  1. Chromo Inc. T2 Battery Replacement, Removing the Casing: Schritt 1, Bild 1 von 3 Chromo Inc. T2 Battery Replacement, Removing the Casing: Schritt 1, Bild 2 von 3 Chromo Inc. T2 Battery Replacement, Removing the Casing: Schritt 1, Bild 3 von 3
    • Place your Plastic Opening Tool between the screen and the case. Slowly move it around the casing while prying in a downward motion to undo the hinges holding the two together and separate the two parts.
  2. Chromo Inc. T2 Battery Replacement, Turn it around: Schritt 2, Bild 1 von 1
    • After separating the case and screen, turn your screen face down so you can see the internal parts!
  3. Chromo Inc. T2 Battery Replacement, Freeing the Battery: Schritt 3, Bild 1 von 3 Chromo Inc. T2 Battery Replacement, Freeing the Battery: Schritt 3, Bild 2 von 3 Chromo Inc. T2 Battery Replacement, Freeing the Battery: Schritt 3, Bild 3 von 3
    • Using the Spudger, going between the battery and screen, pry the battery off from the tablet.
    • Note: This will require a little extra force due to the tape holding down the battery!
  4. Chromo Inc. T2 Battery Replacement, Desoldering the Battery Wires: Schritt 4, Bild 1 von 1
    • Using a Soldering Iron, desolder both Battery wires.
    • Soldering Iron gets very hot, take care to not touch anywhere on the soldering iron except for the handle!
  5. Chromo Inc. T2 Battery Replacement, Finished!: Schritt 5, Bild 1 von 1
    • Your battery is now ready to be replaced!
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
USF Tampa, Team 15-1, Watkins Winter 2015 Mitglied von USF Tampa, Team 15-1, Watkins Winter 2015
USFT-WATKINS-W15S15G1
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 1,559
