Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Ersatzteile
Keine Ersatzteile angegeben.
  1. Using your Plastic Opening Tool, place it in between the screen and the case. Slowly move it around the casing while prying in a downward motion to undo the hinges holding the two together and separate the two parts. Using your Plastic Opening Tool, place it in between the screen and the case. Slowly move it around the casing while prying in a downward motion to undo the hinges holding the two together and separate the two parts. Using your Plastic Opening Tool, place it in between the screen and the case. Slowly move it around the casing while prying in a downward motion to undo the hinges holding the two together and separate the two parts.
    • Using your Plastic Opening Tool, place it in between the screen and the case. Slowly move it around the casing while prying in a downward motion to undo the hinges holding the two together and separate the two parts.
  2. After separating the case and screen, turn your screen face down so you can see the internal parts!
    • After separating the case and screen, turn your screen face down so you can see the internal parts!
  3. Nintendo Switch Kits
    Eine schnelle Lösung, um wieder ins Spiel zu kommen
    Switch Kits kaufen
    Switch Kits kaufen
  4. Remove two strips of tape: One holding down the wires and the other holding down the internal speaker. Remove two strips of tape: One holding down the wires and the other holding down the internal speaker. Remove two strips of tape: One holding down the wires and the other holding down the internal speaker.
    • Remove two strips of tape: One holding down the wires and the other holding down the internal speaker.
  5. Using a Soldering Iron, desolder both speaker wires. Once both wires are desoldered, your Internal Speaker is now ready for replacement! Soldering Iron gets very hot, take care to not touch anywhere on the soldering iron except for the handle! Soldering Iron gets very hot, take care to not touch anywhere on the soldering iron except for the handle!
    • Using a Soldering Iron, desolder both speaker wires. Once both wires are desoldered, your Internal Speaker is now ready for replacement!
    • Soldering Iron gets very hot, take care to not touch anywhere on the soldering iron except for the handle!
Abschluss
Ismael DeLuna
601 Reputation
5 Anleitungen geschrieben
USF Tampa, Team 15-1, Watkins Winter 2015 Mitglied von USF Tampa, Team 15-1, Watkins Winter 2015
USFT-WATKINS-W15S15G1
4 Mitglieder
6 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 150
