Zum Hauptinhalt wechseln
Chumby One LCD Screen Replacement
Was du brauchst
  1. Chumby One LCD Screen Replacement, Chassis: Schritt 1, Bild 1 von 1
    • Remove 4 self-adhesive plastic dots covering the screw holes.
  2. Chumby One LCD Screen Replacement: Schritt 2, Bild 1 von 1
    • Remove the four 2mm screws with a Phillips screwdriver.
  3. Chumby One LCD Screen Replacement: Schritt 3, Bild 1 von 1
    • Remove the back and bottom cover.
  4. Chumby One LCD Screen Replacement: Schritt 4, Bild 1 von 1
    • Disconnect the battery connector from the motherboard with a plastic opening tool.
  5. Chumby One LCD Screen Replacement: Schritt 5, Bild 1 von 1
    • Disconnect the microphone connector from the motherboard with a plastic opening tool.
  6. Chumby One LCD Screen Replacement: Schritt 6, Bild 1 von 1
    • Remove the display ribbon cable from its socket with a plastic opening tool.
  7. Chumby One LCD Screen Replacement: Schritt 7, Bild 1 von 1
    • Remove the volume knob from the side of the Chumby One with a plastic opening tool.
  8. Chumby One LCD Screen Replacement: Schritt 8, Bild 1 von 1
    • Remove the four 6mm screws using a PH000 bit on the inner chassis.
  9. Chumby One LCD Screen Replacement: Schritt 9, Bild 1 von 1
    • Remove the inner components from the outer shell.
  10. Chumby One LCD Screen Replacement, LCD Screen: Schritt 10, Bild 1 von 1
    • Remove the four 5.5mm screws with a Phillips PH000 screwdriver bit.
  11. Chumby One LCD Screen Replacement: Schritt 11, Bild 1 von 1
    • Remove the metal shield from the front case using a plastic opening tool.
  12. Chumby One LCD Screen Replacement: Schritt 12, Bild 1 von 1
    • Remove the LCD screen from the outer case using a plastic opening tool.
Abschluss
Jordan Houchins
401 Reputation
4 Anleitungen geschrieben
IUPUI, Team S3-G3, Baechle Spring 2017 Mitglied von IUPUI, Team S3-G3, Baechle Spring 2017
IUPUI-BAECHLE-S17S3G3
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 12
Insgesamt: 225
