Zum Hauptinhalt wechseln
Chumby One Motherboard Replacement
Was du brauchst
  1. Chumby One Motherboard Replacement, Chassis: Schritt 1, Bild 1 von 1
    • Remove 4 self-adhesive plastic dots covering the screw holes.
  2. Chumby One Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Remove the four 2mm screws with a Phillips screwdriver.
  3. Chumby One Motherboard Replacement: Schritt 3, Bild 1 von 1
    • Remove the back and bottom cover.
  4. Chumby One Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Disconnect the battery connector from the motherboard with a plastic opening tool.
  5. Chumby One Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Disconnect the microphone connector from the motherboard with a plastic opening tool.
  6. Chumby One Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Remove the display ribbon cable from its socket with a plastic opening tool.
  7. Chumby One Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Remove the volume knob from the side of the Chumby One with a plastic opening tool.
  8. Chumby One Motherboard Replacement: Schritt 8, Bild 1 von 1
    • Remove the four 6mm screws using a PH000 bit on the inner chassis.
  9. Chumby One Motherboard Replacement: Schritt 9, Bild 1 von 1
    • Remove the inner components from the outer shell.
  10. Chumby One Motherboard Replacement, Motherboard: Schritt 10, Bild 1 von 1
    • Remove the speaker connector using a plastic spudger.
  11. Chumby One Motherboard Replacement: Schritt 11, Bild 1 von 1
    • Remove the Chumby button connector using a plastic spudger.
  12. Chumby One Motherboard Replacement: Schritt 12, Bild 1 von 1
    • Remove three 6mm screws using a PH000 bit.
  13. Chumby One Motherboard Replacement: Schritt 13, Bild 1 von 1
    • Remove the motherboard by pulling straight away from the housing.
    • Removing the motherboard there are 2 pins and socket connectors that may cause injury.
Abschluss
Jordan Houchins
401 Reputation
4 Anleitungen geschrieben
IUPUI, Team S3-G3, Baechle Spring 2017 Mitglied von IUPUI, Team S3-G3, Baechle Spring 2017
IUPUI-BAECHLE-S17S3G3
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 12
Insgesamt: 281
