Einleitung
This guide shows how to replace the Chumby One speaker.
Was du brauchst
Disconnect the battery connector from the motherboard with a plastic opening tool.
Disconnect the microphone connector from the motherboard with a plastic opening tool.
Remove the volume knob from the side of the Chumby One with a plastic opening tool.
Remove the four 5mm screws on the speaker base with a Phillips PH00 screwdriver bit.
Fast fertig!
Abschluss
