Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Gefahr
Potenziell gefährlich
Es besteht Verletzungsgefahr, wenn die Anweisungen nicht ordnungsgemäß befolgt werden. Sei vorsichtig und befolge alle Warnhinweise.
Gefahr
Einleitung
Battery no longer lasting a full day? Tried factory reset and still have the same battery life? If you answered yes to any of these then a battery replacement could very well do the trick. Requiring just a few minutes of time, you will be up and running with a recharged tablet ready for what ever is next.
  1. Remove the SIM/SD tray. Carefully prey and lift up around the edge of the device. Take note of the two buttons and keep them in a secure place until reassembly.
    • Remove the SIM/SD tray.
    • Carefully prey and lift up around the edge of the device.
    • Take note of the two buttons and keep them in a secure place until reassembly.
  2. SPAR DIR DAS UPGRADE
    Mach dein iPhone so gut wie neu mit unseren Fix Kits.
    Jetzt entdecken
    Jetzt entdecken
  3. Lift up the LCD cable latch and gently pull the cable out. There are three cables that need desoldered. Extreme caution must be taken when completing this step as any part of wires that aren't insulated touch it could cause fire.
    • Lift up the LCD cable latch and gently pull the cable out.
    • There are three cables that need desoldered. Extreme caution must be taken when completing this step as any part of wires that aren't insulated touch it could cause fire.
    • Remove the strong adhesive holding the battery in place. Care should be taken to avoid bending which could lead to thermal runaway.
    • Solder the three cables to the correct locations.
    • Pull out the old battery carefully and swap in for a new one.
  4. When reassembling, be sure to place the buttons back into their cut outs before reattaching the back plate.
    • When reassembling, be sure to place the buttons back into their cut outs before reattaching the back plate.
Abschluss
To reassemble your device, follow these instructions in reverse order but make sure that the buttons are in place before closing it shut.
3 weitere Nutzer haben diese Anleitung absolviert.
Calvin Hodgson
1.086 Reputation
4 Anleitungen geschrieben
Where can you get a new battery? Do you have a model number?
George Clendenin - Antwort
Additional information: I have Chuwi Hi9 Pro CWI 532 not 548 but according to the picture the the presented wiring and battery placement seems to be the same (buttons are not). Back to the post: the removed flex cable is not the battery cable it is the LCD cable (yellow rectangle). The battery is soldered with 3 cables, see the bottom right corner of the battery on the Step 2 picture. Be very careful when desolder these cables: do one at a time and immediately insulate the soldered out wire to make sure there will be no shortcut. Shorting the red and the black cables could cause even fire if not paid enough attention to this step. Battery glued by two strip to the metal backplate. The strips can not be accessed at the stips’s end because there are shorter than the battery. The strips are strong and can not be heated effectively: you will heat the battery or the screen, be careful doing that. What I recommend is use a thin plastic wire to cut the glue.
Mihaly Miterli - Antwort
Thanks for the useful information. I updated the guide to reflect the part where it needs to be soldered. I did not notice those wires down there at first but that makes complete sense.
Calvin Hodgson -
Battery info for Chuwi Hi9 Pro CWI 532:
Model: PT34100110 (1ICP4/101/107)
3.8V, 19Wh
Max charge 4.35V
According to the picture, model CWI548 uses the same battery.
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 6
Letzten 7 Tage: 20
Letzten 30 Tage: 145
Insgesamt: 1,572
