Einleitung
This guide will take you step by step through the steps of replacing your devices buttons.
Was du brauchst
Remove the top (button side) rubber cover using your hands.
Using your hands, pull off the plastic side cover (on the side with the audio jack) using the indented tab. The indented tab has been highlighted in the picture.
Detach the plastic speaker cover on both the front and back sides. Then slide the cover off of the device.
Remove the five 1 cm screws on the back side (opposite of the speakers) of the device using a Phillips #1 screwdriver.
With a Phillips #1 screwdriver, remove the two 5mm screws which attach the button mount to the plastic casing of the device.
Using a plastic opening tool, pry the button mount off of the plastic casing of the device.
Using a soldering iron and iFixit’s Soldering Guide, remove the individual buttons.
