Was du brauchst
Use a Phillips #00 screwdriver to unscrew the four 1.1mm long screws on each corner located at the top of the cover.
Similar to the last step, flip the cover over and use a Phillips #00 screwdriver to unscrew the four 1.1mm long screws on each corner located at the bottom of the cover.
Remove the warranty sticker across the bottom.
Gently take the cover apart using your hands separating the top and bottom.
The outer shell is expected to easily come apart.
Using the plastic opening tool, wedge the tool underneath the bottom left edge of the hard drive.
Raise the bottom edge of the hard drive 15 degrees up from the device.
Place fingers on the IDE connectors gently picking up and sliding the hard drive out from the IDE module.
Using the Phillips #00 screwdriver, unscrew the two 1.5mm long screws holding the IDE connector to the motherboard located at the top.
Using the Phillips #00 screwdriver, unscrew the three 1.5mm long screws on the metal bracket.
Using the plastic opening tool, completely lift the metal bracket off of the motherboard.
Using the plastic opening tool, completely lift the rubber insulator off of the motherboard.
Using the plastic opening tool, completely lift the ribbon off of the motherboard.
Completely remove the IDE connector from the device.
The audio jack is attached to the IDE connector. Pull at a 45 degree angle from the audio jack.
Using the plastic opening tool, wedge the tool underneath the top edge of the motherboard.
Completely remove the motherboard.
Set aside the front cover.
Flip over the motherboard.
Using the Philips #00 screwdriver, remove the three 4mm long screws holding down the button module.
Using the tweezers, lift up the button module to a 180 degree angle.
Flip over the motherboard with the button module still attached.
Fold the button module over the motherboard.
Using the tweezers, remove the ribbon pin.
Flip over the motherboard so the screen faces up.
Carefully slide the battery off of the motherboard.
Place two fingers on the battery connectors and gently pull the power cable connector completely out from the motherboard.
Eine weitere Person hat diese Anleitung absolviert.
