Einleitung
This is a replacement guide for the Cirago M9030 Cover. The following steps will guide you in the dismantling and rebuilding of the cover as well as a replacement.
Was du brauchst
Use a Phillips #00 screwdriver to unscrew the four 1.1mm long screws on each corner located at the top of the cover.
Similar to the last step, flip the cover over and use a Phillips #00 screwdriver to unscrew the four 1.1mm long screws on each corner located at the bottom of the cover.
Remove the warranty sticker across the bottom.
Gently take the cover apart using your hands separating the top and bottom.
The outer shell is expected to easily come apart.
In order to reassemble your device, follow these instructions in reverse order.
Eine weitere Person hat diese Anleitung absolviert.
