Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Using a Phillips #00 screwdriver, remove the four 1.1mm long screws from the top side.
Using a Phillips #00 screwdriver, remove the four 1.1mm long screws from the bottom side.
Using the plastic opening tool, wedge the tool underneath the bottom left edge of the hard drive.
Raise the bottom edge of the hard drive 15 degrees up from the device.
Place fingers on the IDE connectors and gently slide the hard drive out from the IDE module.
Using the Phillips #00 screwdriver, unscrew the two 1.5mm long screws holding the IDE connector to the motherboard.
Using the Phillips #00 screwdriver, unscrew the three 1.5mm long screws on the metal bracket.
Using the plastic opening tool, completely lift the metal bracket off of the motherboard.
Using the plastic opening tool, completely lift the rubber insulator off of the motherboard.
Using the plastic opening tool, completely lift the ribbon off of the motherboard.
Ein weiterer Nutzer hat diese Anleitung absolviert.
