Einleitung
Whether your circular saw blade is worn out, or you just want to switch it out for a different style, it’s really easy to swap out blades on pretty much any circular saw—and it takes just a few minutes.
This guide uses a Ryobi P504G circular saw, but the process is very similar for most circular saws.
Was du brauchst
Press and hold down the blade lock button to keep the blade from turning while you loosen it.
Loosen the arbor's hex bolt in the center of the blade using a 5mm hex key, making sure to loosen clockwise since the bolt threads are reversed.
Once loosened, continue unscrewing the bolt with your fingers and remove it from the saw.
Set the circular saw on its side and carefully lift up the blade to unseat it from the arbor.
Slowly slide out the blade.
When inserting the new blade, be sure to note its rotation and install it in the correct orientation.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
3 Kommentare
Hello!
I learned a lot of important things, but I have a Question that is this Circular Saw perfect to cut Concrete Pavers?
I think you need a cutting disc in your circular saw
to cut concrete.
