Einleitung
How to replace/upgrade Cisco 878 Router StrataFlash Memory module.
Was du brauchst
Use the Phillips #1 Screwdriver to remove the two screws on back side of the device.
1. Gently push the top cover of the router away from you.
2. Lift it up top cover from the bottom of the router.
3. Remove top cover from the device.
Use the Phillips #1 Screwdriver to remove the three screws on front side of the device.
1. Gently lift up inner metal shield from the bottom of the router.
2. Remove inner metal shield from the device (see the anchors on the picture).
1. Place your fingers on the levers at the two sides of the slot, and push open.
2. Firmly pull the release lever away from the module until the module pops up.
3. You can then remove the module from the module slot.
1. Insert the notched edge of the module into the slot at an angle.
2. Firmly press down the unnotched edge of the module until you hear a click. The indents must be fully in the notches.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
