Zum Hauptinhalt wechseln
Cisco Meraki MC74-HW USB and Headphone Jack Inputs Board Replacement
Was du brauchst
  1. Cisco Meraki MC74-HW USB and Headphone Jack Inputs Board Replacement, Back Housing and Device Stand: Schritt 1, Bild 1 von 3 Cisco Meraki MC74-HW USB and Headphone Jack Inputs Board Replacement, Back Housing and Device Stand: Schritt 1, Bild 2 von 3 Cisco Meraki MC74-HW USB and Headphone Jack Inputs Board Replacement, Back Housing and Device Stand: Schritt 1, Bild 3 von 3
    • Extend the stand as far away as possible from the device.
    • Remove all four 3 mm Hex 2 screws from the stand.
    • A bit with a flexible extension may be needed to remove these screws.
  2. Cisco Meraki MC74-HW USB and Headphone Jack Inputs Board Replacement: Schritt 2, Bild 1 von 2 Cisco Meraki MC74-HW USB and Headphone Jack Inputs Board Replacement: Schritt 2, Bild 2 von 2
    • Lift the stand off the device.
  3. Cisco Meraki MC74-HW USB and Headphone Jack Inputs Board Replacement: Schritt 3, Bild 1 von 3 Cisco Meraki MC74-HW USB and Headphone Jack Inputs Board Replacement: Schritt 3, Bild 2 von 3 Cisco Meraki MC74-HW USB and Headphone Jack Inputs Board Replacement: Schritt 3, Bild 3 von 3
    • Insert a plastic spudger between the back housing cover and the sensor cover piece.
    • Work your way slowly around the edges of the device until all the clips have been unclipped.
    • Do not insert any tool recklessly into the device or you might damage wires and connections.
  4. Cisco Meraki MC74-HW USB and Headphone Jack Inputs Board Replacement: Schritt 4, Bild 1 von 2 Cisco Meraki MC74-HW USB and Headphone Jack Inputs Board Replacement: Schritt 4, Bild 2 von 2
    • Separate the back housing cover from the device completely.
  5. Cisco Meraki MC74-HW USB and Headphone Jack Inputs Board Replacement, USB and Headphone Jack Inputs Board: Schritt 5, Bild 1 von 2 Cisco Meraki MC74-HW USB and Headphone Jack Inputs Board Replacement, USB and Headphone Jack Inputs Board: Schritt 5, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Kaufen
    • Disconnect the ribbon cable on the board using a pair of reverse tweezers.
    • Electronic ribbons are very fragile, so pull slowly to disconnect them.
  6. Cisco Meraki MC74-HW USB and Headphone Jack Inputs Board Replacement: Schritt 6, Bild 1 von 3 Cisco Meraki MC74-HW USB and Headphone Jack Inputs Board Replacement: Schritt 6, Bild 2 von 3 Cisco Meraki MC74-HW USB and Headphone Jack Inputs Board Replacement: Schritt 6, Bild 3 von 3
    • Remove the three 2 mm screws holding the USB and headphone jack inputs board using a JIS #00 screwdriver.
    • Carefully lift the board until you have clear access to the electronic connector.
  7. Cisco Meraki MC74-HW USB and Headphone Jack Inputs Board Replacement: Schritt 7, Bild 1 von 2 Cisco Meraki MC74-HW USB and Headphone Jack Inputs Board Replacement: Schritt 7, Bild 2 von 2
    • Disconnect the electronic connector on the board using a pair of reverse tweezers.
    • Carefully lift the board to remove it from the device.
Abschluss
Jeremy Chdid
198 Reputation
1 Anleitung geschrieben
UMass Dartmouth, Team 1-5, Simcock Fall 2021 Mitglied von UMass Dartmouth, Team 1-5, Simcock Fall 2021
UMASSD-SIMCOCK-F21S1G5
4 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 7
Insgesamt: 131
