Einleitung
This guide will walk the reader through the process of replacing the hands of an 1102 series Citizen watch using an iFixit jimmy, tweezers, and a needle. This repair will require minimal knowledge of watches, and can be performed in approximately 10-15 minutes.
Was du brauchst
Locate the notch under the back cap of the watch. Wedge the jimmy into the notch, and pry off the back.
Remove the crown stalk by placing the needle in the release notch. This will release stalk and allow it to slide out.
Gently pry the watch hands off of the face of the watch with the jimmy and tweezers.
Press the back cover on the watch using hands or clamp, until it pops into place.
Now that the watch hands are repaired, the watch can be reset manually so that the it can keep the correct time.
