Einleitung
This guide will show you how to disconnect the control link and remove the handle assembly of a Clarke EZ-8 Floor Sander.
Schritt 1 Disconnect all power cables
Achtung: Schritt 1 stammt von einer Anleitung, die derzeit bearbeitet wird.
Slide the collar on the control link arm up until the two halves of the arm detach from one another.
Pull up on the latch at the bottom of the handle assembly, then remove the retaining plate from its slot in the handle.
Pull up on the handle assembly and remove it from the sander.
