Einleitung
This guide shows how to remove and replace the glued-on grip face pad for the Clarke Floor Sander 07014A.
The process involves prying the old grip face off of the base plate with a putty knife, removing the adhesive residue, and adhering a new grip face on.
Was du brauchst
Twist and pull the dust bag collar to disconnect it from the elbow pipe.
Remove the dust bag.
Lock the handle in place by pulling the lock lever upwards.
Test the lock by wobbling the handle and making sure that it is not loose.
Brace the wheel axle with your foot and grasp the handle with both hands.
Slowly tilt the handle downwards until it rests on your work surface.
Press the edge of a putty knife or flat scraper into the adhesive layer sandwiched between the grip face pad and base plate.
Push and wiggle the putty knife to slice into the adhesive.
Slide the putty knife along the edge to slice through the adhesive.
Apply force to the handle and wiggle the putty knife to help with the slicing.
Continue slicing into the adhesive.
Once you have a sizable area detached, pull on the grip face pad while you slice to help with the process.
Continue slicing until you have detached the grip face pad.
Remove the grip face pad.
Use a powered wire wheel brush, putty knife, or scraper to remove large chunks of adhesive.
Alternatively, spray the entire surface with Xylene or other solvent that dissolves adhesive, let it soak for ten to fifteen minutes and the adhesive will peel off with minimal effort.
Remove any remaining residue with a fine wire wheel brush or coarse (50~100) grit sander. The final surface should feel smooth.
Clean the surface with some isopropyl alcohol.
Peel the replacement grip face pad's adhesive liner one inch from a short edge.
Carefully line up the grip face pad to the base, ensuring that all the edges line up.
Press the right edge of the pad (with exposed adhesive) onto the base.
Pull the adhesive liner from behind the pad and remove it to expose the remaining adhesive.
Look at the liner you just pulled out and make sure it hasn't ripped and left some of the liner on the back of the pad.
Press the grip face pad onto the base plate.
Press the red pad back onto the grip face pad.
Carefully swing the sander back upright so that its weight presses against the base plate.
Allow the sander to sit in this position for an hour to help the grip face pad's adhesive to bond.
17 weitere Nutzer:innen haben diese Anleitung absolviert.
