Einleitung
Follow this guide to replace the blade on a 2018 Classen Sod Cutter model HSC18AHD.
Was du brauchst
Schritt 1 Safety precautions
Achtung: Die Schritte 1-4 stammen von einer Anleitung, die derzeit bearbeitet wird.
Place wheel chocks against the roller and rear wheel to prevent the machine from moving.
Flip the gas shutoff switch next to the motor to the left into the off position.
Grab the plastic housing at the end of the spark plug wire.
Pull firmly to disconnect the wire from the spark plug.
Use a 1/2 inch socket to remove the three bolts securing the cutter blade on the left side of the machine.
Use a 1/2 inch socket to remove the three bolts securing the cutter blade on the right side of the machine.
Slide the cutter blade out from under the machine to remove it.
