Einleitung
Follow this guide to replace the eccentric arms on a 2018 Classen Sod Cutter model HSC18AHD.
Was du brauchst
Schritt 1 Safety precautions
Achtung: Die Schritte 1-4 stammen von einer Anleitung, die derzeit bearbeitet wird.
Place wheel chocks against the roller and rear wheel to prevent the machine from moving.
Flip the gas shutoff switch next to the motor to the left into the off position.
Grab the plastic housing at the end of the spark plug wire.
Pull firmly to disconnect the wire from the spark plug.
Use a 3/4 inch socket to remove the two bolts on the eccentric arm.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
