Einleitung
Follow this guide to replace the lower V-belt on a 2018 Classen Sod Cutter model HSC18AHD.
Was du brauchst
Schritt 1 Safety precautions
Achtung: Die Schritte 1-4 stammen von einer Anleitung, die derzeit bearbeitet wird.
Place wheel chocks against the roller and rear wheel to prevent the machine from moving.
Flip the gas shutoff switch next to the motor to the left into the off position.
Grab the plastic housing at the end of the spark plug wire.
Pull firmly to disconnect the wire from the spark plug.
Use a 1/2 inch socket to remove the first two bolts from the belt shield.
Use a 1/2 inch socket to remove the third bolt from the belt shield.
Use a 9/16 inch socket to loosen the nut securing the idler pulley until the pulley can freely move up and down the bracket.
Use your fingers to roll the belt. If you cannot twist the belt more than a quarter turn, the belt is sufficiently tensioned. If the belt is too loose, set the idler pulley lower to tension the belt more.
Use a 3/4 inch socket to remove the bolt securing the eccentric arm to the blade arm.
Remove the plastic washer from in between the eccentric arm and the blade arm.
Move the cutter blade handle back to disengage the blade drive and relieve tension on the V-belt.
Lift the eccentric arm to open a space to remove the V-belt.
Remove the V-belt.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
