Zum Hauptinhalt wechseln
Classen Sod Cutter HSC18AHD 2018 Upper V-Belt Replacement
Was du brauchst
  1. Achtung: Die Schritte 1-4 stammen von einer Anleitung, die derzeit bearbeitet wird.
    Classen Sod Cutter HSC18AHD 2018 Upper V-Belt Replacement, Safety precautions: Schritt 1, Bild 1 von 2 Classen Sod Cutter HSC18AHD 2018 Upper V-Belt Replacement, Safety precautions: Schritt 1, Bild 2 von 2
    • Make sure the engine is off and cool to the touch before you proceed.
  2. Classen Sod Cutter HSC18AHD 2018 Upper V-Belt Replacement: Schritt 2, Bild 1 von 1
    • Place wheel chocks against the roller and rear wheel to prevent the machine from moving.
  3. Classen Sod Cutter HSC18AHD 2018 Upper V-Belt Replacement: Schritt 3, Bild 1 von 2 Classen Sod Cutter HSC18AHD 2018 Upper V-Belt Replacement: Schritt 3, Bild 2 von 2
    • Flip the gas shutoff switch next to the motor to the left into the off position.
  4. Classen Sod Cutter HSC18AHD 2018 Upper V-Belt Replacement: Schritt 4, Bild 1 von 2 Classen Sod Cutter HSC18AHD 2018 Upper V-Belt Replacement: Schritt 4, Bild 2 von 2
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
  5. Classen Sod Cutter HSC18AHD 2018 Upper V-Belt Replacement, Remove the belt shield: Schritt 5, Bild 1 von 2 Classen Sod Cutter HSC18AHD 2018 Upper V-Belt Replacement, Remove the belt shield: Schritt 5, Bild 2 von 2
    • Use a 1/2 inch socket to remove the first two bolts from the belt shield.
    • Use a 1/2 inch socket to remove the third bolt from the belt shield.
  6. Classen Sod Cutter HSC18AHD 2018 Upper V-Belt Replacement: Schritt 6, Bild 1 von 2 Classen Sod Cutter HSC18AHD 2018 Upper V-Belt Replacement: Schritt 6, Bild 2 von 2
    • Remove the belt shield.
  7. Classen Sod Cutter HSC18AHD 2018 Upper V-Belt Replacement: Schritt 7, Bild 1 von 1
    • Use a marker to mark the height of the idler pulley on the bracket.
  8. Classen Sod Cutter HSC18AHD 2018 Upper V-Belt Replacement: Schritt 8, Bild 1 von 1
    • Use a 9/16 inch socket to loosen the nut securing the idler pulley until the pulley can freely move up and down the bracket.
    • You may need to use a 3/8 inch wrench in combination with the socket wrench to hold the bolt in place.
  9. Classen Sod Cutter HSC18AHD 2018 Upper V-Belt Replacement: Schritt 9, Bild 1 von 1
    • Raise the idler pulley to relieve the tension from the V-belt.
  10. Classen Sod Cutter HSC18AHD 2018 Upper V-Belt Replacement: Schritt 10, Bild 1 von 1
    • Remove the V-belt.
  11. Classen Sod Cutter HSC18AHD 2018 Upper V-Belt Replacement, Reassembly tip: Schritt 11, Bild 1 von 1
    • Check that the idler pulley is properly tensioning the belt:
    • Use your fingers to roll the belt. If you cannot twist the belt more than a quarter turn, the belt is sufficiently tensioned. If the belt is too loose, set the idler pulley lower to tension the belt more.
Abschluss
Sam Omiotek
72.472 Reputation
288 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 8
Insgesamt: 398
