Einleitung
When you have been riding a RipStik (also known as RipStik Classic Caster Board (15055040) by Razor) for a long time or need a new change in style, changing your wheels is vital for the safety of your ride. I will show you how to switch out old wheels for brand-new ones and give your ride a fresh new feel. It takes little skill to complete this task. All it takes is around 8 minutes and minimal hardware work to ensure the safety of your next RipStik ride.
Was du brauchst
Use 2 5mm Allen Wrenches on both sides of the wheels and rotate both wrenches counterclockwise to take out the wheel, axle bolt, screw bolt, and 2 washers.
Slide the axle bolt through the hole on the outside and place the washer on the inside.
Slide the axle bolt out just enough to place the wheel in the middle.
Slide the axle bolt through the middle of the wheel to hold the wheel in place.
Insert the screw bolt through the outside of the caster wall to go through the washer and the wheel.
Much like step 1, use 2 allen wrenches to screw in the wheel and secure it in place.
To replace your old RipStik wheels with brand new ones. Simply follow these steps and enjoy a brand-new ride!
