Einleitung
Do you own a Lookah wax vape, The Swordfish, Unicorn Mini, Q7 Mini, Seahorse X, Python, or Dragon Egg vape? These all Use the Lookah 710 Wax Coils
If you own one of these devices, then you will want to know how to clean the coils that fit in those devices.
This step by step guide will detail the full cleaning process.
Was du brauchst
Remove the coil: Take the coil out of your device.
The coils will unscrew counter clockwise.
Wipe off excess: Use a Q-tip and a little isopropyl to wipe off any excess wax inside the coil. Wipe around the walls and mop up any excess wax. Use a tissue and a little isopropyl to wipe down the outside of the coil.
Soak it: Place the coil in a bowl of cleaning alcohol (90% Isopropyl alcohol) for 30 minutes.
Wipe outside: Remove the coil from the alcohol. Wipe off any alcohol around the outside of the coil. Wipe inside: Use a Q-tip and clean the inside of the coil gently. Don't press down on the quartz plate, which could damage it.
Heat the Coil: Screw the coil back onto the Lookah vape, turn on the vape (5 clicks). Set the voltage to the highest setting. Then heat the coil 3 or 4 times. This will burn off the excess residue from the coil
Eine weitere Person hat diese Anleitung absolviert.
