Zum Hauptinhalt wechseln
Cleaning 1985-1988 Volvo 740 Throttle Body
Was du brauchst
  1. Cleaning 1985-1988 Volvo 740 Throttle Body, 1985-1988 Volvo 740 Preparing Car For Work: Schritt 1, Bild 1 von 2 Cleaning 1985-1988 Volvo 740 Throttle Body, 1985-1988 Volvo 740 Preparing Car For Work: Schritt 1, Bild 2 von 2
    • Firstly Disconnect battery
    • Always take the negative terminal off first.
    • '''General Tip After disconnecting the battery leave the car for about 10 mins , This lets any residual energy left in the electrical system to dissapate. It is good practise whatever the job
  2. Cleaning 1985-1988 Volvo 740 Throttle Body, Removing Throttle Body: Schritt 2, Bild 1 von 1
    • Locate throttle body on right side of engine, it is between the intake tube and intake manifold.
  3. Cleaning 1985-1988 Volvo 740 Throttle Body: Schritt 3, Bild 1 von 1
    • Locate throttle linkage cable assembly.
  4. Cleaning 1985-1988 Volvo 740 Throttle Body: Schritt 4, Bild 1 von 2 Cleaning 1985-1988 Volvo 740 Throttle Body: Schritt 4, Bild 2 von 2
    • Twist the assembly clockwise.
  5. Cleaning 1985-1988 Volvo 740 Throttle Body: Schritt 5, Bild 1 von 1
    • Slide both slackened cables off assembly’s guides.
  6. Cleaning 1985-1988 Volvo 740 Throttle Body: Schritt 6, Bild 1 von 2 Cleaning 1985-1988 Volvo 740 Throttle Body: Schritt 6, Bild 2 von 2
    • Locate the two hoses on the top of the throttle body.
    • Gently lift the hoses off.
  7. Cleaning 1985-1988 Volvo 740 Throttle Body: Schritt 7, Bild 1 von 1
    • Use a flat head screwdriver to loosen the hose clamp attaching the intake tube to the throttle body.
  8. Cleaning 1985-1988 Volvo 740 Throttle Body: Schritt 8, Bild 1 von 1
    • Remove the intake tube from the throttle body.
  9. Cleaning 1985-1988 Volvo 740 Throttle Body: Schritt 9, Bild 1 von 1
    • Locate wiring clip on the underside of the throttle body.
  10. Cleaning 1985-1988 Volvo 740 Throttle Body: Schritt 10, Bild 1 von 2 Cleaning 1985-1988 Volvo 740 Throttle Body: Schritt 10, Bild 2 von 2
    • Press down on the locking mechanism before gently removing the wiring clip.
  11. Cleaning 1985-1988 Volvo 740 Throttle Body: Schritt 11, Bild 1 von 3 Cleaning 1985-1988 Volvo 740 Throttle Body: Schritt 11, Bild 2 von 3 Cleaning 1985-1988 Volvo 740 Throttle Body: Schritt 11, Bild 3 von 3
    • Locate throttle linkage arm.
    • Open the locking clip with a flat head screwdriver.
    • Pry off the linkage arm with a flat head screwdriver.
  12. Cleaning 1985-1988 Volvo 740 Throttle Body: Schritt 12, Bild 1 von 3 Cleaning 1985-1988 Volvo 740 Throttle Body: Schritt 12, Bild 2 von 3 Cleaning 1985-1988 Volvo 740 Throttle Body: Schritt 12, Bild 3 von 3
    • Locate the three 13mm nuts attaching the throttle body to the intake manifold.
    • Remove nuts with a 13mm crescent wrench.
  13. Cleaning 1985-1988 Volvo 740 Throttle Body: Schritt 13, Bild 1 von 1
    • Lift the throttle body off of the intake manifold.
    • The manifold is now out of the engine bay and ready for cleaning or adjustment.
  14. Cleaning 1985-1988 Volvo 740 Throttle Body, Cleaning 1985-1988 Volvo 740 Throttle Body: Schritt 14, Bild 1 von 2 Cleaning 1985-1988 Volvo 740 Throttle Body, Cleaning 1985-1988 Volvo 740 Throttle Body: Schritt 14, Bild 2 von 2
    • Cover the electrical contacts with a shop towel to prevent throttle body cleaner from inadvertently spilling over.
  15. Cleaning 1985-1988 Volvo 740 Throttle Body: Schritt 15, Bild 1 von 1
    • Liberally apply throttle body cleaner to the inside of throttle body and butterfly valve.
    • Use a shop towel sprayed with cleaner to wipe off thick grime if severely dirtied.
  16. Cleaning 1985-1988 Volvo 740 Throttle Body: Schritt 16, Bild 1 von 2 Cleaning 1985-1988 Volvo 740 Throttle Body: Schritt 16, Bild 2 von 2
    • Spray electrical cleaner on the metal contacts to blast away particles in the bracket.
    • Spray off the wiring clip that attaches to the throttle body inside the engine bay.
  17. Cleaning 1985-1988 Volvo 740 Throttle Body: Schritt 17, Bild 1 von 1
    • Apply a small amount of dielectric grease to the metal contacts to prevent corrosion.
Abschluss
To reinstall the throttle body after cleaning follow reverse directions for prerequisite guide #2
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Raymond
76 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 3-28, Regan Fall 2010 Mitglied von Cal Poly, Team 3-28, Regan Fall 2010
CPSU-REGAN-F10S3G28
4 Mitglieder
9 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 20
Insgesamt: 7,852
