Zum Hauptinhalt wechseln
Cleaning Panasonic NB-G110P Toaster Oven Power Switch
  1. Cleaning Panasonic NB-G110P Toaster Oven Power Switch, Remove the Switch Button: Schritt 1, Bild 1 von 1
    • Before starting this guide make sure the toaster oven is unplugged.
    • If the switch still works and isn't failing yet, simply try cleaning it.
    • Pry off the grey plastic on-off button to expose the head of the on/off switch.
    • Apply some electrical contact cleaner (CorrosionX or MG Chemicals Super Contact Cleaner or something similar) or, less ideally, 91% or better isopropyl alcohol to the switch.
    • Work the switch a bit by turning it on and off a lot (still unplugged) and see if that doesn't fix the problem.
  2. Cleaning Panasonic NB-G110P Toaster Oven Power Switch, If Cleaning Doesn't Work (or Stops Working): Schritt 3, Bild 1 von 1
Abschluss
Fixit Clinic
620 Reputation
2 Anleitungen geschrieben
Global Fixers Mitglied von Global Fixers
Community
24 Mitglieder
369 Anleitungen geschrieben
Ein Kommentar
I cleaned my switch…it works great now! Thank you!!!!
Thea G - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 2
Letzten 7 Tage: 7
Letzten 30 Tage: 22
Insgesamt: 681
